Login problems
Dedpuhl
For the past few days, I have had the same problem. I cannot stay logged into the forums.
I go to the login screen, enter my ID and password, check the stay logged in option, and enter. However, I do not get logged into the forums. This started happening Sunday.
The only way I am able to post is if I enter my password and username EVERY time.
Any reasons why this is happening??
thanks
you probably have your internet security settings set way too high and it is forbidding ANY cookies to be stored to your harddrive. Did you change any IE settings sunday?
