Lock won't turn in ignition
daveymark
10,573
2000 Toyota Sienna.
Sometimes the key would not turn in the ignition. but sometimes it would.
I bought a new ignition lock cylinder from toyota, and it came with a new key.
I installed the new lock cylinder, put the new key in. It turned over, but did not start.
I'm guessing this is because the new key's transponder code does not match the vehicle?
So I put the old cylinder back in, and I get the same problem - the key turns over, but does not start.
Does the fact that the key has a transponder affect the situation?
I'm wondering if maybe the car locked itself down from starting at all because I tried to start it with the new key with a different code...
amdskip
22,530
13
Have you tried resetting things by unhooking the battery? Just throwing that out there as something to maybe try.
daveymark
10,573
I figured it out. there is a light ring around the key hole that I didn't hook back up - turns out it's also the transponder receiver antenna :)
