Hi all. This is my first home build and I've run into some issues. Basically the system will lock up while gaming (rather quickly when all the eye candy is turned up, even with the original Unreal Tournament) though not completely. If I hit ctrl alt delete the monitor will go black, then pop to a desktop view with some pieces blacked out, go black, and gradually add more detail as it blacks out and comes back. CPU usage goes to 100% and the sound keeps playing, repeating after about 10 seconds.
here's a list of what my system has:
300 Watt Antec PS
A7N8X (1001.E Bios)
2x256Mb Kingston 333Mhz DDR
1.0 gig T-bird w/ Alpha PAL8045 heatsink
WD SE 80Gig 7200 Rpm
GeForce4 ti4200 64Mb
Windows XP Pro
I've tried windows 2000 as well and about 4 reformats and reinstalls to no avail. I've downloaded the latest drivers from Nvidia and Asus but the same thing happens. the odd thing is that running CPU burn-in for 3 hours only heats the CPU to 38ºC, as does running 3dmark2001SE on a loop for 3 hours (scores around 9000 marks too). Nothing feels particularly hot inside the computer, I've tried clocking my video card much slower but that didn't help stability. I've played with ram timings and that doesn't help either. It's just that if I play the Unreal 2003 demo it'll lock up within the first minute. Some other games will run but will ocassionaly have all sorts of funky stuff blur the screen then return to normal.
If anybody can help point me down a path to check out, I'd really appreciate it. If not, does anybody know of a good computer repair shop that can help in the Southern California area?
300 Watt Antec PS
A7N8X (1001.E Bios)
Windows XP Pro
