loadup problem on games with my comp
I have a problem with my games with loadup. i tried to load some games. It dont want to load. The first screen shows up for instance with bf2 but afterwards it stops. with other games like area 51 and lord of the rings. It just give me a error. I tried to update my drivers but that didnt work. I tried to do a windows update and it still doesnt work. I also get memory dumps. At least 2 in a day. All my no game programs work. Like ares, office, antivirus and others. I have no clue as to whats going on. Please someone help.
Raise your memory voltage to 2.7 volts and see if that stabilizes it at all. Also, for your system, you should have the nVidia motherboard drivers installed, DirectX 9.0C (Start > Run > dxdiag to check version), and of course nVidia video drivers, do you have all of those?
yes i have all those things. the weird thing is that, i sent a error report and they said that its my video drivers thats causing all this. Also it did start around the time that i got the new drivers in it. so im wondering whats going on here. i also thought it might be a heat issue. so i moved my hds. and cleaned out all of the fans. So any other suggestions.
When you run dxdiag.exe, what does it say in the Display tab for DirectDraw Acceleration, Direct3D Acceleration and AGP Texture Acceleration? Are they all Enabled?
What format do your games run under, Direct3D or OpenGL?
When i ran dxdiag.exe, everything came back enabled. i also ran tests everything came back normal. I started dxdiag.exe again. it said that there was a problem the last time i used direct 3d. So i decided to disable it. so i hope that works for now.i wanna get my old drivers back, but i i tried to uninstall my current ones and then reinstall my old ones but cant find my cd. So i have to use the ones that i currently have. if anyone has anything else they could help with. thanks.
