- Feb 4, 2009
- 35,862
- 17,403
- 136
Something I have been thinking about.
Let’s say you have four screws/bolts in a square pattern in standard 2x4 lumber and it is a reasonable length let’s say two feet, if you screw four mounts that hold 60 pounds each that are level and are in a box form does the finished hanger hold 240ish pounds?
I know some will be lost to uncontrollable things like the wood or them not being perfectly level.
Is there a simple formula to know how much multiple mounting things can safely hold?
