Can a computer be connected to a network wirelessly and wired at the same time. I know that the obvious answer is NO because the least problem you will get is a duplicate name on the network.
My scenario is that we have a wireless network in my workplace. Some of us have laptops that are docked and constantly connected via cable but we sometimes undock them to visit other offices. The theory is that the wireless connection automatically and flawlessly kicks in but it doesn?t. It takes a few seconds or more and since we have roaming profiles, we loose sync with the file servers for too long sometimes and sorts of weirdness happens. Of course we also get this problem when we hit a wireless blackspot but I?m wondering if we can prevent it happening when the wired connection is disconnected.
Can you perform a routine for a smooth switchover for example? Maybe prime the wireless connection and disable the Ethernet one or something like that.
XP
Intel 3945ABG driver ver. 10, 11 or 12
Centrino laptops
XP
Centrino laptops
