I thought I understood how to overclock but apparently not. In fact, after some tests this morning I probably don't have the slightest idea 😵
My board is Gigabyte Z77X-UD3H, CPU is 3770K.
Recently I read several guides or postst that insisted people should and have to use LLC. I originally read that to find the proper level of that, one should see what the unchangable displayed vcore value (this) in BIOS settings say and compare it to what actually gets pumped into the CPU under load in Windows. Based on that I shouldn't need anything higher than lowest LLC value: BIOS says 1.085-1.090V and that's what I get with zero offset. It fluctuates a tiny bit of course, I guess based on the level of load, but I assume it's normal. Very occasionally it drops to 1.080V, but usually stays at 1.092V.
Anyway...
Recently I managed to get almost stable (crash after 21 hours) overclock of 4.4GHz with lowest LLC and an offset of +0.040V. Vcore is in 1.116-1.128V range then.
Just for the record, I can boot into Windows and run Prime95 for up to a few hours even with zero offset at 4.4GHz. Yes it's far from stable and I get WHEA errors, but it sort of works (see below why I mention this).
This morning I found some post somewhere saying the way to do this is to set static vcore, boot into Windows, start Prime95 (or whatever one uses), and compare. This is when the pile of WTF comes in, because 1.120V wouldn't even boot properly or just flat out crash Prime95 right away, and I had to set LLC to medium to keep it going for at least a little while. What's more important though, vcore was reported to be 1.080V with that setting. I didn't see any such huge drop under load (in fact none at all) when using offset.
What the hell is going on? Could someone explain?
Anyway...
