I have an alpha 8942t w/ an 80mm Ys-Tech adjustable fan that at high ofr 3800rpm has 48.5cfm.....Right now my p4 2.4@3.24ghz w/ 1.61 gets 37-39c idle and loads at 49c....
I am moving to a P4c 2.6@3.5ghz (aiming for with a max voltage of 1.65v)......w/ HT on
The question is do you think the alpha can cut it???
If not I am looking at these items:
heatsinks:
1)Thermalright SLK-947U (~$38@newegg)
Fitted for 92mm fan
a) VANTEC's ThermoFlow TF9225. 58.5cfm (3100rpm) Temperature Control Sensor Adjust 92mm
(~11+5.00@newegg)
2) Zalman CNPS7000-Cu Pure Copper CPU Cooler for AMD XP Socket 462 & 754 and Intel Socket
478. (~42.00+6.00@newegg). Has 92mm fan unsure on rpm and cfm at normal mode.
Do you like these??? Do you think my current cooper core alpha can do as good of a job??? Can I get a 80mm to 92mm adapter and just upgrade the fan???
heatsinks:
Fitted for 92mm fan
(~11+5.00@newegg)
