And there is your folly. You bought the "exact amount of wood" for a project, without having said wood and measuring.
I don't know about that man. If you go look at older houses they actually really are 2x4's in them. Not smaller. A little different is fine but not an entire half inch.
I mean I know what a 2x4 is these days. But it's frustrating to go buy the other hundreds of woods out there and always have to bring a tape measure and check because none of the labels are the actual size. I don't think it's just the curing, they cut them smaller too. Probably try to save money. Probably some drying and tolerance is ok but I bet they cut them smaller and then blame it on drying and curing these days. And at some point I think code made it ok for 1 1/2 x 3 1/2 in houses but they kept calling them 2x4 anyway.
I'm just saying the actual size would be incredibly useful.
Hammers (Common Name) *not made from actual ham*
I call it a fake story to get people (the right) riled up. Google "Lowes pays $1.6M settlement over 2×4 labeling" and you'll find nothing. Jeez, who falls for this stuff?
Lumber nothing, I bought a box of nails and it didn't contain a single penny! I was robbed!
For the 96 inch length to they measure on the inside of the bow or the outside?
People who don't understand that the measurements don't match the labels are ignorant, not stupid. Insisting there's no difference between the two is stupid, however.
Why would anyone care what the wood's pre-curing dimensions are unless they're buying it pre-cured? The same goes for pre-cooked and cooked weights for food; the only reasons to use the former are: 1. to make it look like the customer is getting more than they really are, or 2. to cling to tradition with no regard for what actually makes sense.
My point was that calling those planks 2x4 is just as arbitrary as calling them standard boards. The common name has no bearing on the product you're actually buying.
They should fine drive manufacturers for the same thing.
Warning: The drive is advertised as 3TB because we convert units using powers of 10, not powers of 2 like we should. This will actually appear as 2.72TB to your operating system.
Doesn't that depend on the file system used? I thought for example that ext was different in formatted size than NTFS?
Generally 1024KB=1MB but when they advertise hard drive sizes, the math used is 1000KB=1MB.
If it's a fake story, the only reason it's believable is because it's California. Hear that Californians? The rest of the country thinks you guys are a bunch of...except it does. a 2x4 stud of douglas fir you buy at the store has the particular dimensions: 1 1/2" x 3 1/2" x 92 5/8". Anyone who is expected to buy these should be expected to know the dimensions of the item they're buying. If they don't, they should be pointed at and mocked.
Most if not all local jurisdictions required graded and stamped lumber as per building code, and the process of getting the stamp alone would cost the same as pre stamped kiln dry lumber that are dimensional stable as well as dried to the correct level of moisture.I don't know about that man. If you go look at older houses they actually really are 2x4's in them. Not smaller. A little different is fine but not an entire half inch.
Because, we'd have to give arbitrary names to every size of lumber then. What would we call a 1x1, 4x4, 6x6, etc?
The reason it isn't called the "actual dimensions" is because after being cut into 2x4 lengths, the curing processes compacts the wood, reducing the size.
People who don't understand this, are stupid.
seriously i knew a 2x4 was 1.5x3.5 when i was like 5
I sure hope it's fake and gay.
