liteon LTD 16x DVD stuck 1.9x while ripping!! help!!
rojkai
70
arg..i thought this drive was supposed to be superior to others when it comes to dvd ripping...somehow..mine is stuck at 1.9x all the way through..any suggestions as to why this is the case ? its set as a secondary slave drive..perhaps that mite be the case ? any help would be appreciated..thanks..
ripthesystem
571
is the media you are ripping scratched or dirty?
is it only this one CD or everyone you try?
just an FYI- my Lite-on 16xDVD rips like lightning so there is definately a problem here somewhere but we need more info
ripthesystem
Eug
23,954
1,575
<< is the media you are ripping scratched or dirty?
ripthesystem
He's talking about DVD ripping not CD ripping.
By the way, my Pioneer 104F 10X DVD-ROM drive rips at about 2.5X. DMA enabled. Drive is independent from HD IDE channel.
rojkai
70
just realized that dma wasnt enabled..but even after dma is enabled, the speed jumped from 1.9x-2.0x which isnt much of a difference..the dvd rom is on a separate ide cable from the hd:
hd->primary master
cdrw->primary slave
dvd->secondary slave
and no..the media is not dirty, scratched..
ripthesystem
571
my bad.. I didn't read carefully enough.
regardless though with my drive (lite-on 16x DVD) I can rip a DVD in 10 minutes or so.. not sure of the exact speed but I'd say 10-15 minutes is a fair guess.
My old 5xDVD (generic Compaq) could do it in around 30 minutes..
I use Smartripper... what proggy are you using?
also:
<< hd->primary master
cdrw->primary slave
shouldn't your DVD be the secondary master?
ripthesystem
Boobers
799
I recently updated the BIOS in my Lite-On 16X from version GH4F to GH5K. With the old BIOS, and using the latest SmartRipper, it would rip DVD's at ~12X (start @ 4X, end @ 14X). Since I changed the BIOS, it now rips at 4X across the entire disk. The newer Lite-On BIOS cripples the drive, lowering it's DVD rip speed to an annoying level. Their BIOS flash program will only flash new, updated BIOS's and will not allow you to flash a BIOS older than the BIOS currenty in the drive. I can't even go back to the BIOS I had. I would warn anyone with a Lite-On DVD LTD163 that is still a fast ripper NOT to update their BIOS or you will LOOSE your fast DVD rip speed.
I feel that they ripped me off by selling me a drive that was the fastest ripper, then crippling the drives read speed with the new BIOS after the drive is bought and paid for.
Their web site says that the read speed is determined by many factors, such as disk quality, scratches, etc, and the drive automatically adjusts for optimal read speed based on the quality of the media. EVERY DVD I put in it reads @ 4X, from a brand new, spotless DVD, to a scratched rental DVD.
They also say that if copying disks from the DVD to a CDR on-the-fly, it will adjust read speed so that it reads slightly faster than the writer. The example they give is that if you're writing at 24X, the DVD will read at 25X. This is BS!!! If it encounters a read error, this leaves NO time for a retry.
I've owned this drive for one year now, and the tray barely slides out. It groans and creaks and I wouldn't be surprised if it stops working soon. Imagine that, it just made it out of the one year warranty period.
I am really disappointed with Lite-On and will probably never purchase any of their products ever again. Right now I'm looking at an Asus DVD with ATA100 interface. Interesting...
