It would save a lot of time if you gave needed information in original posting. Think your problem out and post whatever you think might be relevant. Such as (in this case):
Which version of Adaptec came with your burner?
Which version of Windows are you running?
What are the capabilities of your hard disk controller. EIDE,UDMA-33/ 66/100?
Many recent versions of Adaptec software packaged with drives install version 4.02d and have a directory on the CD called update or upgrade.
In that directory is an upgrade to 4.02e which supports several varieties of BU prevention technologies. install that update and any available from the Roxio web site (I believe there is a 4.03x, but you must have W98 or higher to use). Adaptec burning software is now handled at
www.roxio.com.
You can tell if DMA is enabled by:
-Rt.click on My Computer
-Click on Properties
-Click on Device Manager Tab
-Click on + sign next to CD-ROMs
-See list of CD-ROM drives installed.
-DblClick on your burner name.
-Click on Settings tab.
-See if DMA box is checked or not.
Roxio says to unclick DMA (IOW, turn DMA off for the burner)--don't ask me why...
.bh.
