Liteon 24x burner DAO/Nero problem
Venner
Hey. Has anyone else had any problems burning images in Nero? I ripped a couple of CDs to Nero .nrg files and when I loaded them to burn, Nero spat back :
Start of burn process at 16x(2400KB/s)
Invalid field in parameter
Could not perform start of Disc At Once
Burn Process Failed at 16x(2400KB/s)
This happened both with the 5S01 firmware and the 5S07, and I'm using Nero 5.5.4.0. Any ideas?
I really really want DAO mode, as I make/burn a lot of VCDs too. What's going on?
Actually I am having the same problem. I have the 16x 102b model and whenever I try to do a disc to disc copy that is exactly the error message I get. I am running the same version as you, win2k, trying to copy from my primary slave dvd drive to my secondary master burner. The thing is, it worked fine for a while, then one day I just started getting this message. Can someone please help?
