Lite on max burn speed not reported correctly with Nero
jblondi
538
Just got my new 24x liteon burner installed. Everything went fine, ive got the latest firmware, and upgraded nero software. The problem comes with how nero reports the drive. If I select the drive info it comes up as saying the max write speed is 20x, when it should be 24x. Any one else have this problem. This was the bundled software that came with the drive from newegg, so I figured it would at least work at the max speed. Thanks.
John
Moderator Emeritus<br>Elite Member
4
What does the device manager report the drive as?
jblondi
538
it shows up as Lite-On LTR 24102B...im assuming the 24 is the max write speed, so it looks correct.
John
4
<< Nero will report the maximum speed of the media you have in the drive I think... >>
I use a Liteon 24102B and Nero 5.5.6.4 w/ 16x Imation CDR's and burn @ 24X no problem. Try and run the updated version.
jblondi
538
no, not true, I have 16x CD's in the drive....Here is what shows up under the drive properties in nero
Pic
jblondi
538
I have the updated version....just to repeat. What shows up under your drive specs john?
John
4
Damn I missed the part about you updating NERO, lol.
NERO says my drive is:
Reads CDR / CDRW24x max speed
5S54 firmware
Supports overburn
smart burn
2MB buffer
cd text and disc at once supported
jblondi
538
well, any suggestions to fix it?
and Paulson...does your drive show 20x or 24x in the nero drive properties
Paulson
10,689
www.ifixidevices.com
Recorder information for LITE-ON LTR-24102B
Medium types: CD-R/RW
Maximum Speed: 24x (3,600 KB/s)
Firmware Revision: 5S54
Overburn: Supported
Buffer underrun protection: SMART-BURN
jblondi
538
alright, so the problem is narrowed down...anyone have any suggestions on how I can get my drive to report correctly
pmark
921
This happened to me too when I updated to the latest firmware. Now instead of burning at 24x it burns up to 16x on certain CDRs, but this only happens with Nero. If I use CloneCD then it burns at 24x.
I just burn at the 16x speed when I use those cds and Nero, really not that big of a deal.
jblondi
538
well, everyone else has the newest firmware without this problem so that doesnt help
John
4
Try Adaptec EZ Coaster maker and see what happens.
jblondi
538
I just uninstalled and reinstalled Nero...that fixed it. Now myself and my new burner can live a long and happy life.
