- Apr 25, 2003
- 5,742
- 1
- 0
Linkage to the download page.
IMPORTANT:
This latest release of firmware is the Final version available for updating the phased out LVD-2001.
There will be no future firmware release for LVD-2001.
[Bug fixed]
Though system not support UDF file system , but system will show a warning message once mount disc fails.
Added AVI patch for audio and video are not played synchronously.
OSD will show invalid if input length is longer than actual file length when execute time search function.
The new setting will take effect unless exit setup menu.
System will hang from tray out or power off system if enable and disable subtitle alternately when playback AVI file.
Subtitle content will be cut-off if more then 5 lines.
Subtitle display and file information display confliction problem.
P-scan symbol on VFD will be cleared after reset system.
[Feature Added]
Support OGG playback.
Folder structure support.
Support .JPEG & .MPEG & .DIVX file format.
Display language code in DVD subtitle & DVD audio.
Cursor can move up/down while playback ISO data disc file.
Support repeat folder mode.
Define,,[ENTER] keys to adjust subtitle timing when play AVI file.
Only read subtitle files which have the same file name as AVI file, not for all subtitle files of the disc.
Modify character set mapping rule of polish language.
System will return to file list if the position of F.F is over than actual video length.
