Lite on iHBS112 will not burn any DVD's no matter how hard I try
DPOverLord
No matter what I do, I have had 0 success burning any DVD's to this drive. I have moved it from my marvel to J micron to my intel ports and it always says burn process failed.
I tried again with Nero and got:
[17:35:10] ExpressUI Burn process completed successfully
[17:35:15] AMCUIBase Setting 'en-US' as Nero File Dialog language
Then just burning regular files I just get a failure.
I am assuming this is a driver or some setting I have wrong.
Would love any help, this is an OEM Lite on Drive I purchased from Tiger Direct back in August.
Thanks!
Edit: Trying a DVD+R DVD and it seems to be working. However a DVD-R from TDK does not work at all.
Do you have any ideas why +R would work but -R would fail?
If you're having problems with a particular set of media it is one of two things:
1) A compatibility problem that cannot be fixed.
2) A compatibility problem that can be fixed by a firmware update to the drive.
There are no drivers that will generally affect the performance of an optical drive. Your storage controller drivers may have a marginal impact, but not enough (usually) to cause it to make coasters or fail to burn.
Follow this link to see if firmware can be updated:
http://www.liteonodd.com/en/bd-internal/item/bdinternal/ihbs112#
When is it failing? During calibration? Lead-in? Data? Lead-out? Verification?
What speed are you burning at?
What speed is the media rated for?
What is the media code (MID) of the disc?
Also, ImgBurn is better in part because it shows you things like the MID.
If I had to venture a guess, it's because you're using substandard media and burning them too fast. But that's just a guess, since there isn't much to go by.
I tested it with a DVD+R (RW) disc from Verbatim that is about 6 years old and it burned without an issue.
On my old Plextor DVDRW drive these DVD-R disks from TDK would work no problem. The only thing I have been able to burn is a 2meg file of memtest.
I am using Nero to burn the media so I know now it's not "technically a driver issue, but Driver Detective lists the ATAPI iHBS112 SCSCI CDROM Device as Invalid
The media is rated at 16X
I downloaded IMGBURN, how do I find hte MID, and everythign else? The Media has been good thus far with my other drives
Here is the code error at the end:
[17:34:10] AMC 16:48:14 #2 Text 0 File Cdrdrv.cpp, Line 10814
[17:34:10] AMC ---- Disc Structure: Physical Format Information of Control Data Zone in the Lead-in (10h) ----
[17:34:10] AMC Media Type: 0, Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
[17:34:10] AMC Book Type: DVD-R (2), Part Version: 2.0x (5), Extended Part Version: 2.1 (33)
[17:34:10] AMC Disc Size: 120 mm, Maximum Transfer Rate: <not specified> (F h)
[17:34:10] AMC Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
[17:34:10] AMC Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
[17:34:10] AMC Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
[17:34:10] AMC Outer Limit of Data Recordable Area: 26127F h
[17:34:10] AMC Data in Burst Cutting Area (BCA) does not exist
[17:34:10] AMC Revision number of maximum recording speed: 6.0
[17:34:10] AMC Revision number of minimum recording speed: -
[17:34:10] AMC Revision number table of recording speed: 1.0 2.0 3.0 4.0 5.0 - -
[17:34:10] AMC Class: 0, Extended part version: 33
[17:34:10] AMC Start PSN of the Extra Border Zone: 2FE10 h
[17:34:10] AMC Start PSN of Physical format information blocks in Extra Border Zone: 2FFA0 h
[17:34:10] AMC Media Specific [16..783]:
[17:34:10] AMC 00 60 00 10 20 30 40 50 - 00 00 00 21 00 00 00 00 .`...0@P...!....
[17:34:10] AMC 00 02 FE 10 00 02 FF A0 - 00 00 00 00 00 00 00 00 ..þ...ÿ.........
[17:34:10] AMC 00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
[17:34:10] AMC 1D 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
[17:34:10] AMC 01 40 C1 FD 9E D8 52 00 - 02 84 0D 12 98 99 90 00 .@ÁýžØR..„......
[17:34:10] AMC 03 43 4D 43 20 4D 41 00 - 04 47 2E 20 41 4D 33 00 .CMC.MA..G..AM3.
[17:34:10] AMC 05 88 80 00 00 00 02 00 - 06 09 0D 14 98 88 90 00 ................
[17:34:10] AMC 07 88 80 00 00 00 00 00 - 08 07 17 0A 0E 09 04 00 ................
[17:34:10] AMC 09 95 07 0D 0B 88 88 00 - 0A 80 00 00 00 00 10 00 .•..............
[17:34:10] AMC 0B 06 17 15 B8 99 85 00 - 0C B8 9A 32 03 20 32 00 ....¸.…..¸š2..2.
[17:34:10] AMC 0D 00 00 D0 00 00 00 00 - 0E 09 1F 39 2F 25 1C 00 ...Ð.......9/%..
[17:34:10] AMC 0F 50 19 29 19 89 B5 00 - 10 88 84 00 04 00 04 00 .P.).‰µ...„.....
[17:34:10] AMC 11 00 00 00 00 00 00 00 - 12 09 2B 37 2D 29 1B 00 ..........+7-)..
[17:34:10] AMC 13 50 1D 2D 1F A6 B5 00 - 14 88 80 00 00 00 00 00 .P.-.¦µ.........
[17:34:10] AMC 15 00 00 00 00 00 00 00 - 16 0B 45 3D 3B 1F 25 00 ..........E=;.%.
[17:34:10] AMC 17 30 25 31 0D 8A B5 00 - 18 88 80 00 00 00 00 00 .0%1.е.........
[17:34:10] AMC 19 00 00 00 00 00 00 00 - 1A 0C 51 51 51 45 2D 00 ..........QQQE-.
[17:34:10] AMC 1B 90 23 2D 19 79 B5 00 - 1C 88 80 00 00 00 00 00 ..#-.yµ.........
[17:34:10] AMC
[17:34:10] ExpressUI Burn process failed with status 3
[17:34:15] AMCUIBase Setting 'en-US' as Nero File Dialog language
Smart Pack reads it as iHBS112 2 firmware PL06 which is the latest firmware
Smart-burn reads it as
Boot Code = 0L05
Drive Type = BD
Drive S/N = 3772512014 216148500676
CD/DVD Life Record Count = 6
CD/DVD Record Count = 2
BD Life Record Count = 1
BD Record Count = 1
Disc Type = DVD-R (Single Layer)
Disc MID = 43 4D 43 20 4D 41 (CMC MA)
Disc TID = 47 2E 20 41 4D 33 (G. AM3)
Nominal Capacity = 4.38GB
Manufacturer Maybe = CMC Magnetics Corporation
SMART-BURN Speed Limit = 16.0X (Write)
Try it at a lower speed. I personally like to burn all my DVDs at 6x because that's the highest CLV (constant linear velocity) speed. (For Blu-Rays, it's 4x) In my experience, going at the maximum 16x speed even on media rated for that speed and even on a drive that officially supports that speed is a crapshoot. They are fine near the start of the disc (where it's burning slowly) but then develop problems towards the end when the speed has ramped up.
PS: Since you have a LiteOn drive, it supports media scanning, so Nero CD Speed's quality test can be run on it. I wonder what that would look like for a failed burn.
This^^
Also avoid any speeds that utilize ZCLV or ZCAV. Those sudden jumps in recording speed can lead to media with bad spots.
There is a useful little setting in Nero that lets you see the actual speed your drive is recording at. Its buried somewhere in "settings->advanced" if I remember right. I'd try starting at 2x to see if you can get a successful burn.
