Lite-On DVD Drive Issue
jshabouk
All:
I just finished by new build with the Asus P5W DH Deluxe and C2D E6400 chip. Everything works great, but now my Lite-On SOHW-1693-S drive dowsn't read disks anymore. I had to put my older Pioneed DVD drive in the machine. I updated the drive firmware, but no luck. It will recognize disks in Windows XP Pro x64 edition, but when you try to run executables or copy, I get IO errors and other stuff (sorry I can;t be more specific).
Is there a BIOS setting I need to check out or change to get this drive to read correctly? Or is there a distinct possibility that this drive died in the course of 30 minutes of being moved (very delicately) from one case to another?
Advice would be GREATLY appreciated!
Is the drive recognized by BIOS and windows? Did you install windows off of the Pioneer or did you pull a quick switcheroo on the new build (i.e. put old HDD in new computer, and didn't reinstall windows?).
Drive was recognized by Bios, Installed Windows off it. When I went to install the motherboard drivers and video card drivers (as well as my other software), it would come back with read errors. I tried copying files to the HDD, but that failed as well. That was when I put in the Pioneer and it (the Pioneer) worked perfectly.
Ok...problem SOLVED...In building the computer, I used the IDR cable that came with the motherboard marked for the CD-ROM drive. This was a 40 Pin-40 wire cable, not a 40 Pin-80 wire cable which is needed by high speed drives! I switched the cable out for another I had and PRESTO! DMA mode for both drives and the Lite-On works!
