Lite-on 40x12x48 problems
Johnnie
May 28, 2000
8,444
MSI K7N420
XP1700+
2-256 2100 DDR
60G WD
72x Kenwood
Win XP Pro
I did have a 24x lite on..replaced it with the 40x.
booted up...tried to burn...got the BSOD :(
uninstalled Nero...installed the latest version ....tried to burn..very slow!!
installed new firmware update..no help :(
any ideas?
obenton
2,012
Did you install the nVidia Unified Drivers? Available on MSI support site.
Johnnie
May 28, 2000
8,444
i even tried a clean install of XP Pro...loaded all the right drivers..went to MS update..downloaded the cd burner update...I still get the BSOD says bad_spool_caller
I think I'll just go back to my 24x lite-on !!
Dreadogg
1,780
no offence but why in the world would you upgrade from a 24 x to a 40 x would you think that you would see that much improvement?
WarCon
3,920
I am sure you have done this, but have you gone and downloaded the latest nero? My nero wouldn't work with IAA until I did that.
Johnnie
May 28, 2000
8,444
using the Nero that came with the burner
version 5.5.7.2v
Heretik
931
You double check to see if your Nero 5.5.7.2 is recognizing your burner? Mine came with Nero 5.5.7.2 also, but wouldn't recognize the burner, I had to go to Nero site & download newest version (5.5.8.0) and update it.
CraigRT
31,440
Is there not patches out for Windows XP? I thought Windows XP gave burners a hard time.. if you look on some software websites, (burning software) they have released patches for WinXP.. it is possible you need some sort of patch...
