mikeyboy714
I installed XP (dual boot with already running Me), and install Roxio Easy CD Creator 5.02 platinum and cdrwin 4.0. CDRWin doesn't recognize my burner, and easy cd says it has problems initializing the engine. At first, it said it couldn't load the ASPI engine, then I tried installing ASPI drivers (first from the ones on the Roxio CD, then from the net, then goldenhawk drivers) with no luck. Now, it just says initializing failed. I tried using the XP update for roxio, and now it just crashes. Any ideas how to fix this?
