David Yang
hey all,
it seems that whenever i listen to mp3s off an external USB hard drive, my system eventually slows down to a crawl after awhile. at first i thought it was just a problem with itunes and wmp being slow, but this continued to happen after i switched to winamp. the windows task manager would list winamp as using something like 25 megs of memory and 55% of the cpu. i highly doubt that's normal.
i suspect that my system slows down because of the constant reading from the external hard drive. i have about 40 gigs of mp3s on a maxtor 120 gig external drive (USB 2 interface).
so my questions are:
1. how much load do USB devices, particularly hard drives, put on the cpu? is my theory a plausible one?
2. do you guys know of any sort of "system bottleneck" utility that i can use to figure out just what it is that's slowing down my computer?
thanks a bunch.
dell latitude d600 1.4 ghz pentium M
maxtor 3000LE
thanks a bunch.
maxtor 3000LE
