Liquid Cooling???? Will it work
thescreensavers
9,916
in simple terms does he need a dual core ready water cooling kit or any soket 939 will work.
remember about the clip that puts pressure on the center of a amd 64 cpu or dual core wich puts the presser on the whole cpu.
Cerb
17,484
33
86
It will work. Sockets 754, 939, and 940 all use the same retension mechanism. If it can handle two 130nm Opterons (Linux Journal's '05 Ultimate Linux Box, IIRC), it should work fine for 90nm dual-cores (which actually run cooler). :)
NINaudio
526
4
For that price you'd be able to get better results with your own custom setup using dangerden or swiftech parts.
