Liquid cooling question. Upgrading to PETG
yes... you need to get fittings for hard pipe if your going PETG.
But lemme give u some advice... unless ur experienced with custom LCS, i would advise against it.
PETG builds require lots of planning, and also lots of patience.
You also NEED a dedicated drain valve, and line, for maintenance.
Other then that PETG has 1 advantage over regular tubing, it isnt as pourous, so your loss of coolant from the tubing being porous over time becomes very small.
