Liquid cooling pump started to make noise
alanwest09872
when I woke up this morning my Liquid cooling pump was making a strange noise. I need to know if I should be concerned.
Its kind of strange it makes noise for about 1 sec then stops for 1 sec then starts again. over and over again.
It kind of sounds like a low level Grrrrrr............Grrrrrr.............Grrrrr. Sorry its the best way I could think of explaining it.
anyone know what this could possibley be
Edit: I have refilled the unit and shook it to get the air bubbles out and the noise is still there.
If it was low it's possible that there might be air still trapped in the pump. Guess you could try tilting the rig around and see if it helps. If not it might be best to replace the pump just in case it's on it's way to the promised land.
Are you sure it's not one of the fans? Might be worth a look to see just in case.
it would help to tell us if u have an AIO or a Custom..
And if its either, what you have.
