Originally posted by: Tsuwamono
ya for sure man. infact just to get used to building PCs before your first build. buy a 200$ POS from some local computer store like a p3 or p2 or something and just take it apart and rebuild it over and over and over until you get used to it. Also try reformating and installing windows, swaping parts using different cables. This should give you alittle experience for building your first computer.
Actually I've done with with a dell with a P3, I rebuilt that thing several times already, getting better at it, I just never reinstalled windows before, is that part hard?
it's as hard as setting the 1st boot device to cd-rom in BIOS and then popping in the windows CD, then installing a bunch of drivers
nice, I'll do that, drivers are easy?
