Linux sound problem
Rifter
Ok here is the deal, i just built a completly new compuer consisting of the following:
ASUS M3A78-EM(780G chipset im using onboard analog audio)
AMD quad core 9650(i think thats the model, its a Phenom 1 2.3Ghz quad core)
4GB PC1066(memory is stable runs memtest86+ for hours at 1066 speed)
Seagate SATA 1TB 7200.11
Samsung SATA DVD burner 22x
Linux Mint 6 all updates installed
The problem is that all my mp3's skip(not alot but maybe 5 to 10 times per song), i know its not the files cause when i upload them to my celphonel it plays them fine, also if i burn an audio CD from the files it plays fine in my car and under linux/windows. Also the same files play fine with windows. I am using VLC in both linux and windows and the default player in mint also skips on mp3's. Video however does not skip at all using the same player(i mean the audio in videos or video playback). Im at a loss. The only thing i can think of is Linux seems to be switching the cores in use by VLC or the default player very rapidly between my first and forth core, could that be causing the skipping? can i lock in VLC to only use one core? if so how. Thanks! Also im not OC anything
EDITED TO ADD: The windows machine the files play fine on is not the same box! thanks!
I seem to have it under control now and i will explain what i did in the hopes it will help others having similer problems.
1st I Maxed out VLC's priority in the system monitor, this helped but did not eliminate the skipping, say 30-40& less skipping obtained.
2nd I went into VLC's Menu Tools>Preferances and cliked on the show all bullet (default was simple only) I then proceeded using the menu to go to Audio/Output modules. This menu has 4 options, i changed two of them, the ALSA Device name from Default to my onbord audio (HDA ATI SB: AC888 Analog for me)
I then changed the OSS Menu to have the only tick box ticked to turn on Try and work around buggy OSS drivers. Changing these two options eliminated the rest of the skipping and made the audio cleaner sounding.
I hope this can help someone.
I haven't had that issue, but thanks for taking the time to update :^)
It would be nice if everybody did that....
~Cool. Thanks for the info!
How do you like Mint 6?
I've been running Mint 6 x64 for a few weeks now - and I'm loving it!
I've only had a few issues:
  1. I had to compile my own driver for the integrated WiFi chipset in this lappy. Took about an hour.
  2. SSH wouldn't work with my web server in Atlanta. Fixed it by uncommenting a line in the /etc/ssh/ssh_config file (GSSAPIAuthentication no)
  3. ICQ didn't work in Pidgin, but a Pidgin/libpurple update fixed that yesterday. Pidgin was using an old, outdated version of the ICQ protocol.
It seems like the updates are about a week behind Ubuntu, but that's fine, because none of the updates have broken anything - due largely to the Mint rating system, I'm sure.
Anyway, glad you fixed your problem and posted it here!
I stream my music/audio/video mostly, and haven't had any problems, but I might want to use the CD/DVD, some day, for something other than data...
Mint is awesome now that i have a bit of a feel for it. I have never used linux before two days ago so i went into this blind 🙂 Now that im getting used to it i dont know why anyone uses windows anymore other than for gaming. Im selling my copy of vista when it arrives next week. I was going to dual boot because the girlfriend wanted windows for working on work related files and minor vid encoding/editing, but she says she likes openoffice and linux better than windows with MS office. Also the vid tools i downloaded for her to use she says are better. I never thought i would hear her say that as every time i suggested loading linux in the past she looked at me like i was growing horns and said she could never figure it out, typical MS brainwashing 🙂 She now says going from windows 2000 to Mint 6 was more easy for her to learn than 2000 to Vista which she just switched to at work. Did linux used to be a real pain in the ass cause i was expecting ALOT more trouble than ive had so far. I mean its like windows but stable and fast and way more memory efficient.
You have no idea dude :^D
Ubuntu and it's variants are probably the easiest Linux to get into. Even with them, if you have the misfortune of having unsupported hardware, it can be enough to make you toss your comp out the window :^D
Linux is easier than ever, and if you have the right needs, it can replace Windows on the desktop. As for me, Vista is my favorite O/S, followed by Ubuntu.
Heh! Interesting comments! You're a 'follow through' kinda guy... I can see that - even though you're afraid to commit to your GF! 😉
In particular...
...every time i suggested loading linux in the past she looked at me like i was growing horns...
And...
She now says going from windows 2000 to Mint 6 was more easy for her to learn than 2000 to Vista...
I can relate to both of those declarations!
When I tell ppl that I run Linux, they look at me like I have horns (even ppl that otherwise respect me and hang onto my every word). None of them are willing to follow me down that path!
Having more-or-less skipped the "XP craze" (even though I'm forced to use it at work daily) I think that the move from Win2K to Linux on-the-desktop is a natural progression.
Put another way, if you're still running Win2K (as I am, on most of my machines) you'll probably cream your shorts over the current offerings in the Linux on-the-desktop community!
I can't really say the same would apply to XP and Vista fans. They're a breed onto themselves... 😀
The funny thing is, I h-a-t-e Ubuntu and l-o-v-e Mint 6, even though the core files are the same! It's ALL in the execution - the interface, the package handler, and so forth. Mint 6 rules, and Ubuntu drools! Mint 6 is the XP MCE / Vista Home Premium of the Linux world!
I have an Ubuntu user in this household (that cosied up to my Ubuntu 8.10 experiment) that h-a-t-e-s Mint 6 (because it looks like Windows) but l-o-v-e-s Ubuntu because... Um... It looks like Ubuntu...
So, my friend, it looks like you and your GF lucked out, the first time 'round!
Congratulations with your new (virtual) baby!
LoL!
I would be remiss if I didn't reflect on this...
I cut my Linux teeth on Debian, well into the last century. I liked it just fine, but couldn't get any support from fellow Debian users, because they were all in Nordic countries - and there was a HUGE language barrier! So, I tried this n' that distribution, and finally settled on Caldera. Big mistake!
Next, I got hooked on FreeBSD (which I still think is the best server OS), but that community is full of stuff shirts! If you have a problem with BSD, you better have tried everything in the world to fix it, and be prepared to prove you tried everything in the world, before asking for help. Otherwise... forget it!
Considering your 'horns' comment, and my response - check this out: http://www.youtube.com/watch?v=oC4gsipGfQU
How the hell did Olander publish a 32 min YouTube video, you might ask??? Gotta be the horns!
I'm currently running a Slackware box for our personal web site(s), and using CentOS for our production server, but we're talking desktops...
I tried Linux on-the-desktop about once ever 6 months, ever since the 90's, but nothing interested me until I tried openSUSE 10.3. That was sort of a keeper, but... not really. More of an eye-opener, let's say.
It wasn't until Ubuntu became popular that everything started moving at warp speed! Now, the handwriting is on the wall!
Truthfully, I don't know how MS is going to survive, unless they decide to give away at least one version of Windows (7) for free - and charge for the apps.
The irony of the situation is...
I'm right back to using Debian again, minus the language barrier.
You see... Mint 6 = Ubuntu = Debian! And, I've come full circle!
I suppose, if tradition holds true, I'll be trying PC-BSD next...
Life is weird sometimes, no? 🙂
