Panther505
hHere is the setup:
Local hub with 3 servers on it (2 W2K and and a RH 7.2) One W2K server is a DHCP server, the RH server is a PXE server and the last W2K server is file server. The hub will support no more then 5 clients at a time (by intent). Purpose of the hub is to allow PXE network boot with a menu to select and run 3 possible boot images. the image is unimportant until later.
Problem:
I have installed the PXE and TFTP server on the Linux box. The DHCP server does pass IPs and I do get the boot menu on the client system. I used the default PXE.conf that installed and I moved the vmlimuz and initrd into the TFTP directory as it suggests to try in the README. (This works in a fashion- allows the image to boot). If I add a boot image that functioned on an Intel PXE server i get tftp errors?
Question-
Has anyone seen got this to function?
If so could you post me on how?
I tried to change the image file name in the PXE.conf to see if I could get it to the other boot images but that did not come close. I would like any help that I can get
Problem:
Question-
