Linux problems HELP
Spleeze
I just installed Slackware 10, and I have some questions...
First off, how can i install firefox so it WORKS! I did all that tar -xzvf firefoxblah blah ./firefox-installer stuff, but after i install and browse to the directory in a terminal and type firefox it says it cant find the command.. If i do ls its there though, how can it not find it. Also where should this thing be installed. I thought that my problem might have been where installed it so i sent it so /usr/bin and /usr/local/bin all kinds of places that I cant remember and none of them worked for me... I want it to be installed so all users can just bring up a terminal and type firefox and then it loads... I was also having some wierd stuff happen with the way windows were drawn and not being able to click on file view etc...
Also i have a fat32 partition that i want to be accesable from the linux install, I foolishly didnt add it to my fstab when i installed, thinking I could just mount "insert drive here" but that doesnt work... any hints on this would be great.
Sorry if im kinda hard to follow... Thanks for any replies!
Sounds like you might need to update your PATH variable to include current directory, otherwise, try typing ./firefox from the directory where it is installed.
I haven't looked at a non-native Firefox package in a while, but most of those kinds of packages work similarly. Usually, you can unpack them just about anywhere - I usually put them someplace like /usr/local/firefox. Inside that directory will be some kind of starter file (probably also named firefox, so... /usr/local/firefox/firefox) that's really a script that sets up all the other environment magic for you.
So to start with, try running that file directly - type /usr/local/firefox/firefox (or cd to the directory, and do as Firus suggested). That should probably work, though maybe the filename is really mozilla-firefox or something similar. Also, there's some voodoo with some Mozilla-related packages where it won't work properly until you run the executable as root once (strictly a one-shot thing, something about registering chrome IIRC). So if the script bails out with a weird error, give it one shot as root and see if it helps.
If that works, then it's just a matter of getting things in your PATH, as Firus noted. The easiest way to deal with this is probably to make a symlink from the script to someplace in your path. So you might do something like
ln -s /usr/local/firefox/firefox /usr/bin/firefox
After that, you should be good to go.
I asked very near the same thing about 10 days ago, I was able to get it working with the help of a few here, see the thread Here
