'm ready to beat my head against the wall with this one. My goal was to set up a simple caching-dns/dhcp and proxy server using an old box for my home network. I'm using an older Fedora distro (FC-5) and I'm almost where I want to be but I just can't get my windows clients to successfully communicate with my name server.
Conceptually my network goes like this:
[ISP] >--public IP-->[cable modem]>--192.168.0.x-->{DNS/Proxy/DHCP]>--10.0.0.x-->{Switch]-->[Clients]
1) Public IP assigned to cable modem by ISP
2) Cable modem assigns Linux box a 192.168.0.x on eth0
3) Linux box eth1 has a static IP of 10.0.0.1 and runs DHCP server to assign 10.0.0.x addresses to clients.
4) My server's FQDN is mybox.no-ip.org
So far I have tested DNS caching and verified it works server-side only. DHCP works client side and IPV4 forwarding is enabled as well (I tested this by doing a 'dig' on google server side and entering the real IP address into a browser on a client PC).
My nitty-gritty configuration thus far:
iptables are configured to forward IPV4 traffic between eth1 and eth0 using:
iptables -t nat -A POSTROUTING -o eth0 -j MASQUERADE
DNS is installed and configured per the following files:
/etc/resolv.conf
search no-ip.org
nameserver 127.0.0.1
/etc/named.conf
// named.conf for Red Hat caching-nameserver
acl no-ip.org { 10.0.0.0/24; 127.0/8; };
options {
directory "/var/named";
dump-file "/var/named/data/cache_dump.db";
statistics-file "/var/named/data/named_stats.txt";
query-source address * port 53;
allow-query { no-ip.org; };
forward first;
forwarders { 68.105.28.12; 68.105.29.12; 68.105.28.11; };
// a caching only nameserver config
controls {
inet 127.0.0.1 allow { localhost; } keys { rndckey; };
// Add local zone definitions here.
zone "no-ip.org" IN {
type master;
file "no-ip.org.zone";
allow-update { 127.0.0.1; 10.0.0.1; };
zone "0.0.10.in-addr.arpa" IN {
type master;
file "0.0.10.in-addr.arpa.zone";
allow-update {127.0.0.1; 10.0.0.1; };
zone "." IN {
type hint;
file "named.ca";
zone "localdomain" IN {
type master;
file "localdomain.zone";
allow-update { none; };
zone "localhost" IN {
type master;
file "localhost.zone";
zone "0.0.127.in-addr.arpa" IN {
type master;
file "named.local";
zone "0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0. 0.0.0.0.0.0.ip6.arpa" IN {
type master;
file "named.ip6.local";
zone "255.in-addr.arpa" IN {
type master;
file "named.broadcast";
zone "0.in-addr.arpa" IN {
type master;
file "named.zero";
include "/etc/rndc.key";
These are my local zone configurations
/var/named/chroot/var/named/no-ip.org
$ORIGIN .
$TTL 86400 ; 1 day
no-ip.org IN SOA mybox.no-ip.org. foo.bar.tld. (
2008052903 ; serial
28800 ; refresh (8 hours)
7200 ; retry (2 hours)
604800 ; expire (1 week)
86400 ; minimum (1 day)
NS mybox.no-ip.org.
MX 10 mail.no-ip.org.
$ORIGIN no-ip.org.
mybox A 10.0.0.1
$TTL 10800 ; 3 hours
vsagateway A 10.0.0.253
TXT "3105ceba36a35756c5a108790f90eed83b"
$TTL 86400 ; 1 day
www CNAME mybox
/var/named/chroot/var/named/0.0.10.in-addr.arpa.zone
$ORIGIN .
$TTL 86400 ; 1 day
0.0.10.in-addr.arpa IN SOA mybox.no-ip.org. foo.bar.tld. (
2008052903 ; serial
NS mybox.no-ip.org.
$ORIGIN 0.0.10.in-addr.arpa.
1 PTR mybox.no-ip.org.
253 PTR vsagateway.no-ip.org.
DHCP is configured as follows
/etc/dhcpd.conf
authoritative;
#Server configuration;
server-identifier mybox;
ddns-domainname "no-ip.org.";
ddns-rev-domainname "in-addr.arpa.";
ddns-update-style interim;
ddns-updates on;
ignore client-updates;
# This is the communication zone
zone no-ip.com. {
primary 10.0.0.1;
key rndckey;
# Client configuration:
subnet 10.0.0.0 netmask 255.255.255.0 {
# --- default gateway
option routers 10.0.0.1;
option subnet-mask 255.255.255.0;
option broadcast-address 10.0.0.255;
option nis-domain "no-ip.org";
option domain-name "no-ip.org";
option domain-name-servers mybox.no-ip.org;
# option time-offset -18000; # Eastern Standard Time
# option ntp-servers 192.168.1.1;
# option netbios-name-servers 192.168.1.1;
# --- Selects point-to-point node (default is hybrid). Don't change this unless
# -- you understand Netbios very well
# option netbios-node-type 2;
zone 0.0.0.10.in-addr.arpa. {
primary 10.0.0.1;
key rndckey;
zone localdomain. {
primary 10.0.0.1;
key rndckey;
range dynamic-bootp 10.0.0.128 10.0.0.254;
default-lease-time 21600;
max-lease-time 43200;
My Networking is configured as follows:
/etc/sysconfig/network
NETWORKING=yes
HOSTNAME=mybox.no-ip.org
FORWARD_IPV4=true
GATEWAYDEV=eth0
NOZEROCONF=yes
My Ethernet cards are configured as follows:
/etc/sysconfig/network-scripts/ifcfg-eth0
# Linksys Gigabit Network Adapter
DEVICE=eth0
TYPE=Ethernet
BOOTPROTO=dhcp
HWADDR=00:18:F8:08:F5:36
ONBOOT=yes
USERCTL=no
PEERDNS=no
DHCP_HOSTNAME=mybox.no-ip.org
IPV6INIT=no
/etc/sysconfig/network-scripts/ifcfg-eth1
# Intel Corporation 82801BA/BAM/CA/CAM Ethernet Controller
DEVICE=eth1
TYPE=Ethernet
USERCTL=no
BOOTPROTO=static
BROADCAST=10.0.0.255
HWADDR=00:07:E9:BC:45:78
IPADDR=10.0.0.1
NETMASK=255.255.255.0
NETWORK=10.0.0.0
ONBOOT=yes
IPV6INIT=no
This is what a dig to google.com returns when I run the command server-side:
; <<>> DiG 9.3.2 <<>> www.google.com
;; global options: printcmd
;; Got answer:
;; ->>HEADER<<- opcode: QUERY, status: NOERROR, id: 32634
;; flags: qr rd ra; QUERY: 1, ANSWER: 5, AUTHORITY: 7, ADDITIONAL: 6
;; QUESTION SECTION:
;www.google.com. IN A
;; ANSWER SECTION:
www.google.com. 25 IN CNAME www.l.google.com.
www.l.google.com. 19 IN A 209.85.171.147
www.l.google.com. 19 IN A 209.85.171.99
-----content truncated-----
;; Query time: 1 msec
;; SERVER: 127.0.0.1#53(127.0.0.1) <<<<< DNS Caching functioning from server-side
;; WHEN: Wed May 28 13:13:17 2008
;; MSG SIZE rcvd: 324
Meaning that local DNS caching is working, but it only works server side. When I run an nslookup to www.google.com from a windows client pulling everything by DHCP it returns the following error.
(From Windows DOS Prompt using 'nslookup')
DNS request timed out.
timeout was 2 seconds.
***Can't find server name for address 10.0.0.1: Timed out
***Default servers are not available
Server: Unknown
Address: 10.0.0.1
***Request to Unknown timed-out
Excerpt from /var/log/messages showing successful dhcp/dns startup and a new remote client getting assigned an address without errors:
May 30 08:18:33 mybox dhcpd: dhcpd startup succeeded
May 30 08:19:05 mybox named[3474]: starting BIND 9.3.2 -u named -t /var/named/ch root
May 30 08:19:05 mybox named[3474]: found 1 CPU, using 1 worker thread
May 30 08:19:05 mybox named[3474]: loading configuration from '/etc/named.conf'
May 30 08:19:05 mybox named[3474]: listening on IPv4 interface lo, 127.0.0.1#53
May 30 08:19:05 mybox named[3474]: listening on IPv4 interface eth0, 192.168.0.3 #53
May 30 08:19:05 mybox named[3474]: listening on IPv4 interface eth1, 10.0.0.1#53
May 30 08:19:05 mybox named[3474]: zone 'no-ip.org' allows updates by IP address , which is insecure
May 30 08:19:05 mybox named[3474]: zone '0.0.10.in-addr.arpa' allows updates by IP address, which is insecure
May 30 08:19:05 mybox named[3474]: command channel listening on 127.0.0.1#953
May 30 08:19:05 mybox named[3474]: zone 0.in-addr.arpa/IN: loaded serial 42
May 30 08:19:05 mybox named[3474]: zone 0.0.10.in-addr.arpa/IN: loaded serial 20 08052902
May 30 08:19:05 mybox named[3474]: zone 0.0.127.in-addr.arpa/IN: loaded serial 1 997022700
May 30 08:19:05 mybox named[3474]: zone 255.in-addr.arpa/IN: loaded serial 42
May 30 08:19:05 mybox named[3474]: zone 0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0.0. 0.0.0.0.0.0.0.0.0.0.0.ip6.arpa/IN: loaded serial 1997022700
May 30 08:19:05 mybox named[3474]: zone localdomain/IN: loaded serial 42
May 30 08:19:05 mybox named[3474]: zone localhost/IN: loaded serial 42
May 30 08:19:05 mybox named[3474]: zone no-ip.org/IN: loaded serial 2008052902
May 30 08:19:05 mybox named[3474]: running
May 30 08:21:26 mybox dhcpd: DHCPDISCOVER from 00:e0:b8:53:63:9d via eth1
May 30 08:21:27 mybox dhcpd: DHCPOFFER on 10.0.0.253 to 00:e0:b8:53:63:9d (vsaga teway) via eth1
May 30 08:21:27 mybox named[3474]: client 10.0.0.1#32790: updating zone 'no-ip.o rg/IN': adding an RR at 'vsagateway.no-ip.org' A
May 30 08:21:27 mybox named[3474]: client 10.0.0.1#32790: updating zone 'no-ip.o rg/IN': adding an RR at 'vsagateway.no-ip.org' TXT
May 30 08:21:27 mybox named[3474]: journal file no-ip.org.zone.jnl does not exis t, creating it
May 30 08:21:27 mybox dhcpd: Added new forward map from vsagateway.no-ip.org. to 10.0.0.253
May 30 08:21:27 mybox named[3474]: client 10.0.0.1#32790: updating zone '0.0.10. in-addr.arpa/IN': deleting rrset at '253.0.0.10.in-addr.arpa' PTR
May 30 08:21:27 mybox named[3474]: client 10.0.0.1#32790: updating zone '0.0.10. in-addr.arpa/IN': adding an RR at '253.0.0.10.in-addr.arpa' PTR
May 30 08:21:27 mybox named[3474]: journal file 0.0.10.in-addr.arpa.zone.jnl doe s not exist, creating it
May 30 08:21:27 mybox dhcpd: added reverse map from 253.0.0.10.in-addr.arpa. to vsagateway.no-ip.org.
May 30 08:21:27 mybox dhcpd: DHCPREQUEST for 10.0.0.253 (127.0.0.1) from 00:e0:b 8:53:63:9d (vsagateway) via eth1
May 30 08:21:27 mybox dhcpd: DHCPACK on 10.0.0.253 to 00:e0:b8:53:63:9d (vsagate way) via eth1
Client machines can browse web pages only by entering the actual ip address of the page (e.g. enter 209.85.171.147 if you want to go to www.google.com) via IP Masquerading but no DNS resolution from my caching-nameserver. OTOH, if i set the clients to use one of my upstream DNS servers, they browse the internet just fine (obviously).
The interesting part is that with Windows set to Obtain DNS server address automatically, it gets assined a DNS server of address127.0.0.1 (which is incorrect). No matter; even if I force Windows to use DNS server address 10.0.0.1, name resolution still fails.😕
So that's where I'm at right now. Stumped!!! I just can't seem to get my client side boxes to communicate with my local DNS server... Any ideas on what I'm missing here??
Thanks!
-Adam
/etc/resolv.conf
search no-ip.org
/etc/named.conf
options {
forward first;
controls {
type master;
type master;
zone "." IN {
type hint;
file "named.ca";
type master;
type master;
type master;
file "named.local";
type master;
type master;
type master;
file "named.zero";
$ORIGIN .
$TTL 86400 ; 1 day
2008052903 ; serial
NS mybox.no-ip.org.
$ORIGIN no-ip.org.
mybox A 10.0.0.1
$TTL 86400 ; 1 day
www CNAME mybox
$ORIGIN .
$TTL 86400 ; 1 day
2008052903 ; serial
NS mybox.no-ip.org.
/etc/dhcpd.conf
authoritative;
ddns-updates on;
zone no-ip.com. {
primary 10.0.0.1;
key rndckey;
primary 10.0.0.1;
key rndckey;
zone localdomain. {
primary 10.0.0.1;
key rndckey;
NETWORKING=yes
FORWARD_IPV4=true
GATEWAYDEV=eth0
NOZEROCONF=yes
DEVICE=eth0
TYPE=Ethernet
BOOTPROTO=dhcp
ONBOOT=yes
USERCTL=no
PEERDNS=no
IPV6INIT=no
DEVICE=eth1
TYPE=Ethernet
USERCTL=no
BOOTPROTO=static
IPADDR=10.0.0.1
NETWORK=10.0.0.0
ONBOOT=yes
IPV6INIT=no
;; Got answer:
;; ANSWER SECTION:
Server: Unknown
Address: 10.0.0.1
Thanks!
-Adam
