i am running linux redhat 7.2 kernel 2.4.17
my prob is that as a user i can't mount my windows(ntfs) disk, i have recompiled the kernel for ntfs support
and if i log in as root everything works perfectly.
i would like to mount /dev/hda1 to /mnt/windowsC as a regular user so i dont have to log in as root everytime.
so i did the following....
1) logged in as root
2) created a directory called windowsC in directory mnt (permissions are defaults...drwxr-xr-x 2 root root 4096 Feb 10 19:34 windowsC)
3) changed my fstab file with the following..../dev/hda1 /mnt/windowsC ntfs noauto,user,ro 0 0 (i tried defaults also, no luck)
4) logout as root
5) as a regular user i can do mount /mnt/windowsC (no errors)
6) if i do cd /mnt/windowsC then it gives me error saying that i dont have permission
7) turns out that directory /mnt/windowsC had changed permissions to r-x------, but other devices such as cdroom all have r-xr-xr-x after mounting.....
how do i get it so its the same as that of a cdrom...thanks
4) logout as root
