Linux - Mandrake 7.1 - Network card help, please.
PascaL
I get the following failure when booting into Linux:
Bringing up interface eth0 insmod: lib/modules/2.2.15-4MDK/net/Tulip-o invalid parameter parm_io
[FAILED]
(FYI, "Tulip" is my Linksys 10/100 network card driver)
nullnull
DeeK
700
It depends on which revision of the card you have. Mandrake 7.1 uses Tulip version 0.91g by default, and it won't work if you have a Linksys LNE-100TX revision 4.0. It should work with the revision 2.0 card. The 4.0 rev requires Tulip version 0.92, which can be found at Linksys' page for LNE-100TX under Linux.
