First system specs:
Shuttle SN95G5
Athlon A64 3500+
Crucial 1gig 3200 ddr
HD1: WD 30gig system drive
HD2: Maxtor 300gig SATA
BFG 6800GT video card
I have had my box since around christmas time and run winXP pro as my main OS. My first setup on the box was winxp pro on partition 1 of the 30gig, and Fedora Core 2 on a 200gig drive (partition 1 of 5 gigs and remainder used as storage).
Due to work/school and other things i never really played around in Fedora, but it did seem to run fine (had some difficulties with sound card)
Now, i have decided to load up Fedora Core 3 64bit edition. I have WinXp on the first 24gigs of HD1, and Fedora C3 on the last 5 gigs of HD1. Both boot fine and xp runs perfect. However when I boot into Fedora C3, it runs really jerky. As an example, if i steadily drag the mouse across the screen, every 1-1.5 seconds, it hangs for a split second and then jumps 1/2" to catch up to where it should be. This symptom is constant and seems to be at normal intervals (~1 second)..
What could be causing this? I have done no changes to the Fedora configuration. Could it be the fact that it is at the end of the harddrive? Could i have partitioned the fedora sections incorrectly? i wasnt sure how much to give each partition (root, /usr...etc...)
Please help. i would like to learn linux (i know a little), but this is annoying..
Shuttle SN95G5
Athlon A64 3500+
