I installed Avview on Slackware 8.1 and it finally does something. However, I can't get the audio. Audio does work, I used gamix and kmix to turn the sound up.
I installed TCL/TK and ALSA. They both installed properly. I also installed FFMPEG, but didn't enable it in the configure for AVview. It doesn't compile when I try to enable it. Both AVview and FFMPEG are the lastest versions from cvs.
How do I fix this? Or is there another tv tuner program I should use? I also tried kwintv, but that refused to compile using the lastest cvs.
Edit: Problem resolved. 🙂 There is a separate volume for AIW.
