Linux AVI Problem
Acoshi
187
Is there a codec for the media player totem? Or is there another program that plays .avi files?
Nothinman
30,672
AVI is a generic wrapper, sort of like zip. What matters is the codec of the audio and video streams inside that AVI file.
drag
8,708
win32-codec or something similar will have codecs in the form of windows *.dll files that don't have a native version for Linux. Depends on which distro your using on were to obtain the files.
If your using Ubuntu there are directions in their Wiki and FAQ pages on what to do. Debian you can use apt-get.org to find third party repositories you can add to your source list. Mandrake, Suse, etc you can usually find rpm files that contain the special windows codecs. Gentoo has it, and if your using Fedora you can check out Dag's third party repositories on how to install it (read his FAQ page, its important).
If that is to much or you can't find a proper file or whatnot then you can download the codecs from mplayers codec pages http://www1.mplayerhq.hu/DOCS/HTML/en/codecs.html untar the package and stick them in /usr/lib/win32 and generally most media players will find them.
Also in some cases, like Debian, Fedora, Ubuntu, you have to obtain stuff like linux native LAME encoders from third party places due to legal restrictions. There are howtos and instructions on how to do this.
A AVI file, like stated above, can hold anything. Generally any type of file that is supported
Generally I like VLC. It plays most everything.
calyco
825
Yeah I like VLC too. Kaffeine/w32codecs and VLC work great in Ubuntu, plays almost everything. The Mplayer mozilla plugin though is the only thing Ive found that worked with Apple.com trailers.
