Linux and networking in general questions
tm37
12,436
Posted this in Networking as well and would like to get the same for linux!
I set up a Linux system to run as a file server and internet router, I have been going over the net all evening (much to the shagrin of my pregnant wife) and really haven't been able to find what I am looking for.
I currently have two computers (win XP and win 98) running off my DSL connection through a Netgear RT314 router.
Now I set this up with little knowledge of networking, because not much was needed.
I have set up small (3 or 4) networks (peer to peer) in the past using windows 98.
THe problem is while these served there purpose I accually learned VERY LITTLE ABOUT NETWORKING! Basically name the computers and workgroup map the drive and go. These were relitively easy and when I needed a push in the right direction I got it here or from my IT guy at work. Basically I did the job and while I got it to work I had very little understanding of why it worked. Of course now with this linux comp I have no clue.
Sub-net mask?
Primary DOMAIN?:Q
Basically I have gotten by with what amounts to luck, NOW I NEED HELP, If you know of sites that will help me understand this stuff please let me know I really want to do some hard core reading and get a backround of knowledge before I start asking specific questions again. Also any books that can be had for 30 bucks also might be a good place to start but I would like to start with web if that is possible.
Thanks in advance,
TRAVIS
manly
13,450
4,163
It can be a bit dry at times (because it's text-only)
but the TCP/IP HOWTO for Linux is a document for you to read. There's a lot of stuff in there (mainly the specific hardware sections) that you can skip.
Look for it (and other free docs) at http://www.linux.com/howto
n0cmonkey
42,936
A GOOD computer book for $30?! HAHAHAHAHA!
I spent $65 on tcp/ip illustrated :(
Anyhow, they gave you some good advice. Following it wouldnt be bad.
EDIT: And depending on how much of a geek you are, you may want ot apologize to your wife in advance ;)
