Linksys WMP54G and 64bit XP
strep3241
953
I have a little problem here. I have a Linksys WMP54G v4.51 network adapter and I am trying to install in my new build which is running XP 64bit. Now I know I am having problems because there are no 64bit drivers from Linksys. I did some searching and everybody says to use the ralink drivers but all the links to those drivers are dead.
I went to ralink's website and I downloaded what I thought was the right driver(rt2500) but it did not work. Will I be able to get this to work?
VirtualLarry
56,587
10,225
I'm not a big fan of wireless NIC drivers. I generally use multiple routers flashed to DD-WRT and running WDS mode. That way, you just have to plug in your computer's ethernet port in the LAN port of the WDS router, and it just works.
strep3241
953
I really don't want to get into multiple routers. That can get a little complicated although I have done it before.
I just want to get this adapter working. Is this possible?
Lepard
368
I have gotten this same wireless adapter working on XP64, Vista 64 and Win7 64.
The RT2500 is the correct driver. Are you installing it via Device Manager?
strep3241
953
No, I didn't. I will try through the device manager. Can you give me a link just to make sure I have the right file?
I just tried through the device manager and it can not find the driver. I burned the driver to a cd and it does not recognize any drivers.
If I can't get this one working, what would be a good one to replace it with? I have a Linksys WRT54GS router so do I have to use the same brand of adapter? I have always have pretty good luck with Linksys products. I have thought upgrading to wireless n but would it be beneficial to me? With wireless g products, I receive full strength going through two floors, occasionally it will drop one bar. Is there any advantages to using wireless n or wireless g?
