Hello all. I just built a PC for my kids and cannot get my wireless NIC to hook up with the router. I have a Linksys WRT55AG router/access point/hub for my network. I currently have my main PC hard wired to the router. I also have a laptop connecting to it wirelessly via a wireless-g pc card and an Xbox 360 connecting to it via wireless-a. I've had the occasional hickup with this router dropping connections and had to go reset it. All in all though its been pretty stable - until now. I have spent two nights trying to get my wireless PCI card for my kids computer to connect to the router and have had zero luck! When I first installed the card I didn't follow the instructions exactly and installed the card first before starting the software installation process. When I finished the installation it didn't work so I figured it might have been because I installed the hardware before the software so I uninstallled the software, removed the card, and booted back up and installed the software again. It then prompted me to shut down and install the card so I did. Whe it booted back up I finished the software installation and tried to connect - no luck. I even rebooted a few times to see if something would reset but had no luck. I have repeated the installation process two more times but have hit a brick wall.
I am not very sharp on manipulating the router settings via the browser interface but i do know my way around the options. What exactly all of these settings do - I can't really say, but here again I have had no problems until now. I currently have 128-bit WEP encryption on both the A and G bands. On my kids PC I have set the profile up using the correct encryption and key/pass phrase. Unfortunately my version of the router doesn't have the quick link button on the face to automatically connect the two components up.
The only unique quality to the hardware setup on the new PC with the wireless PCI card is that the PCI slots are extended using a riser card. The case is a barebones kit from Asus (Pundit P1-PH1) and comes with a specially designed mobo and PCI slots. There is one PCI slot on the mobo but is only designed for the riser card to fit in which in turn gives you two slots. I don't think this should be an issue because the PCI card is recognized and all of the software installs correctly. One thing also I didn't mention is that the PCI card sees the available networks. As a matter of fact, it sees my neighbors networks too (not secured, shame on them!). With that said I believe the card is working. My best guess is there is something with the router that may need to be done but I'm no expert on networking so that may not be the case.
Sorry for the marathon post but I wanted to provide as much info as possible to better help you all to assess my issues. Thanks in advance for any help you can provide!
