I am trying to re-set up my wireless network (we moved and i had it setup before, but i can't exactly remember how I did it
I had a router on my computer, and then i had two pcs with wireless network adapters, and one laptop, with a wireless card installed. It was all working great.
My question is...does it matter if i connect my modem using a usb or ethernet? will one of those NOT work with the wireless adapters. Because it seemed before I had it connected with a USB...and it seems like the dsl provider mentioned that i would have to use one certain way for the wireless adapters (but I might just be imagining that).
If I connect with a usb (modem to computer) then i just connect the ethernet from modem to router (router internet port, or one of the numbered ports?) OR can you not set it up like this? does the router have to plug into the PC. I am so confused. I just cant' remember how i had it. does it matter if you use usb or ethernet with the wireless adapters? .....and also, i shouldn't have to do any kind of setup in xp if i had it all setup before?
if anyone can please help--i would greatly appreciate it!!!!!
thanks
thanks
