linksys RV082 dual wan solution?
Oct 16, 2002
142
Does anybody have any real, *recent* experience with the linksys RV082 router?
I know they had some issues when they first came out but there have been a dozen firmware upgrades since.
I am considering getting a couple of these, or using clarkconnect (which I have never used before).
I'm in a situation where quite quickly I have to accomplish 2 things:
1) put in a load balancing dual wan router in one office
2) setup a continuous VPN between that office and another office for file synchronization (I was going to use robocopy (other suggestions welcome if they are there).
I can probably put together a clarkconnect box or 2 but a router just seems easier. I would use m0n0wall but it doesn't support dual wan load balancing. Clarkconnect seems to.
Any thoughts? This seems like it *should* be a good router. There are mixed reviews.
Oct 16, 2002
142
is it fully baked? The site lists it as being alpha software. I won't lose my job but I will get "stern looks" at if I futz around and it doesn't work.
Goosemaster
48,775
ah..in that case skip it...it is supposed to be pretty solid....but that is just hearsay and I wouldn't bet anyones career on it by any means...
How big is the office and what is your budget?
Cisco 800/1800 series might be real nice....they both support on-demand IPsec VPN which is pretty badass
