Linksys router/wireless access point solutions
HyTekJosh
Last minute christmas shopping...
-Anyone know the differences between the WRT54G, WRT54GL, and WRT54GS?
-Any opinions on the WRT54GX, WRT54GX2, and WRT54GX4 (in comparison to the WRT54G/GL/GS)?
Thank you & Happy Holidays!!
wrt54g-standard broadband router
wrt54gs-same thing as wrt54g but with speedbooster that supposely helps with wireless performance (can increase performance by 35% or something like that when used with other speedbooster products)
wrt54gl-standard broadband router but created specially for Linux hobbyists, hackers, ect other then that i really dont know much about it.
I personally use the wrt54gs with the wusb54gs and wpc54gs they all work great barely ever any issue with speed or reliablity.
So the GS uses proprietary SpeedBooster technology that requires compatible SpeedBooster cards and the SRX technology in the "GX" series should work with any B/G card?
All of this thingies (including the Speed Booster) would connect to a regular 802.11b/g Wireless Card.
If you want to take advantage of what ever they offer more then you need a compatible card.
:sun:
