Hello, I have been having trouble connecting my Linksys WRT54GC wireless router to my Netgear WGR614v6. Both have updated firmware. I have followed the instructions that I found online and the setup still does not work. I intend to use the netgear as an extension to the range of my Linksys in terms of wireless connectivity and extra wired ports for that room.
The Linksys is my main router and is hooked up directly to the Cable Modem. My personal computer is hooked up to the Linksys by a standard cat-5. My laptop is communicating wirelessly. I have a standard 50foot Cat-5 cable hooked up to the Netgear router in the other room (the cable was tested to work perfectly fine) by using just the standard LAN hookups and not the WAN or Internet port on the Netgear. Since the linksys ports are such that it does not need a crossover cable, MDX or whatever, I am using a standard cable.
The netgear has DHCP disabled, and its IP is set beyond the range of the Linksys router's IP range.
When I plug the 50 foot cable into the netgear normal port, the light does not turn on signifying that it "is working". If I plug that same 50 foot cable into the back of my second computer, it works fine.
Thanks for your help, and please use simplistic language as networking is the bane to my existance.
