Linksys EtherFast 10/100 PCI Card with Wake-On-LAN $5.99 after MIR
ygreenkitty
190
<< The Linksys EtherFast 10/100 LAN Card is now fully manageable use the Wake On LAN feature to boot up PCs from anywhere on the network. Fully software configurable and Plug and Play compliant, the EtherFast installs in minutes. 32 bit multimaster concurrency technology lets it communicate directly with your PC's CPU, bypassing sluggish interrupts and I/O channels. The EtherFast is available in single, five, and economical 10 packs, making it the perfect choice for rapidly expanding networks. And each one comes with built in support for the widest range of PCI motherboards, networking hardware, and software which means you don't have to worry about compatibility. If your mission critical applications require blinding network speed, the EtherFast LAN Card is the best value for your networking dollar.
Manufacturer's Warranty: Limited Lifetime Warranty
Free Technical Support &amp; Software Upgrades
bigbootydaddy
Banned
Sep 14, 2000
5,820
god, two of these came with my switch, and i am using none of em, and they are real cheap looking, hence the 6 bucks, and they didnt match up to the 3coms obviously, but hey you get what you payed for
Bing
39
bbd -
what measurable performace does the 3com have over the linksys cards? if they are both 10/100 why is one better than the other and in what way?
- just curious!
bing
AdamsJabbar
720
The Linksys 10/100 cards are very excellent. I have built close to 2 dozen computers using these cards. They are about $50 less (on average) than equivalent 3com cards and don't seem to have nearly the problems the 3com cards I've used.
Great deal!
ygreenkitty
190
Yes, I have these in two of my systems, with no problems.
Noticed someone mentioned pointclick has the 10% link--go for the extra $1.59, takes it down to $4.40.
cpebbles
43
Same card here and it's been a joy. Installed the card and was up and running in five minutes. Had some very minor setup problems when I had to reinstall Windows from scratch, but I was having problems getting everything working right at the time.
cpebbles
