Linkskey 4-port Slim Palmtop USB KVM Switch w/Audio
Pardus
Linkskey LKU-S04ASK 4-port Slim Palmtop USB Audio and; Mic KVM Switch, Supports USB Keyboard and; USB Mouse
$49 + ship
LINK
The Linkskey LKU-S04ASK Slim Palmtop USB KVM Switch is a 4-port compact USB KVM Switch with Audio and Mic switching function. The console USB allows you to use USB keyboard and mouse. LKU-S04ASK gives you access, control, boot and reboot four USB-enabled multimedia computers with only one USB keyboard, one mouse, one monitor and optional speaker set and microphone.
Features: 4-port Slim Palmtop USB Audio & Mic KVM Switch. Support USB Keyboard and USB Mouse. USB 1.1 Specification compliant. Supports PC Port Switching. Supports Audio and Microphone Switching. Supports Hot-plugging without Powering down. User Definable Hotkeys. LEDs for easy status monitoring. Supports High VGA Resolution up to 2048 x 1536. USB Interface Power.
Specifications: Model: LKU-S04ASK. PC Connection: 4. Console Connection: 1. Cables: 4 x Integrated HDB 15-pin Cables (USB/VGA Integrated). 4 x Audio/Mic Cables (3.5mm). PC Port Connectors (All Female Type): 4 x HDB 15-pin (For PC Video). 8 x 3.5mm Audio/Mic Jack (For PC Sound). Console Port Connectors(All Female Type): 1 x HDB 15-pin (For Monitor). 2 x USB Type A (For Keyboard & Mouse). 2 x 3.5mm Jack (For Speakers and Microphone). PC selection: Push button / Hotkeys / Switching Software. LED: 4. VGA Resolution: Up to 2048 x 1536. Power Type: USB interface power. Size: Slim Desktop. Housing: Plastic. Dimension (mm): 161 x 70 x 26 (L x W x H). Safety / Emission: FCC, CE.
Package Contents: 1 4-port Slim Palmtop USB KVM Switch. 1 Utility CD-Rom. 1 Quick Installation Guide. 4 Integrated Cable. 4 3.5mm Audio Cable.
thanks op. i was looking for one of these.
however, i am not too crazy about buying from a directron via yahoo store and their shipping was crazy $12 to nj.
i will be buying it from newegg for few extra dollars.
