Linear Algebra...
Sumguy
1,409
My hopes that it has to do with y=mx+b is overshadowed by its placement after diff. eq...hmm...
DrPizza
Mar 5, 2001
49,601
167
111
www.slatebrookfarm.com
It's a course that during the first week, you'll say to yourself "this is fucking easy!! I'm going to ace this course!"
The following week, you'll be saying "eigen-what?"
Chriscross3234
756
I'm currently taking Differential Equations and we use linear algebra to solve systems of equations when using certain methods for solving differential equations. I think there is a class solely dedicated to some deeper subjects surrounding linear algebra that deals with vectors and what not. From what I've been exposed to, its pretty simple, but tedious, stuff.
Pheran
5,740
35
It's all about the matrices. I found it to be quite easy, but I'm good at math, so your mileage may vary.
mesthead21
2,378
Pretty much. It deals with matrices and vectors and whatnot
gwai lo
347
I always remember classifying linear as a class that made very little sense, but gave you lots of useful tools for solving problems later on.
drinkmorejava
3,567
7
It's linear, as opposed to non-linear :)
Probably mostly vector math, eigen stuff, solving matrices using various methods. You may or may not do over-determined systems. Just be happy you won't be doing things like spline interpolation.
zzuupp
14,866
2,319
I was going to say pure evil. But, I like your answer better.
RESmonkey
4,818
My CS roommate said it was pretty easy for him, and that he struggled in Vector Calculus a bit more.
uclaLabrat
5,632
3,045
It's the art of using matrix algebra to solve multiple diff eq's at a time.
acheron
3,171
hahaha, yep, this. :thumbsup:
skim milk
5,784
this has been exactly my experience.
Sumguy
1,409
Hmm...so a bunch of vectors and matrices, got it.
Edit: So I guess the time to reintroduce matrices is a couple of years after I completely forgot how to do anything with them...of course lol
Gibson486
18,378
yup...Algebra in the title is very misleading. That class whipped me hard. It should be named "Linear length is very big so just bend over and take it". I am so happy that stuff is not in my field...although I want to get into robotics....so I am pretty much screwed.
sthaznpride17
252
The calculations and methods are easy. The proofs are what killed me. Prove that this is a linear transformation. the fuck?
Sumguy
1,409
MrPickins
787
I'm taking that this fall as an advanced elective to finish my math minor.
I'm hoping that it will be useful to know for future programming projects.
z1ggy
10,010
66
It seems pretty much liek it should be easier than hell.. but however there is insane amounts of rules and theory which fucking blows. The math isn't anything more than simple alegra..but it involves matrices which can get complicated...and sometimes deals with dif. eq..although no dif. eq type math is involved. All in all I would say it isn't an "easy" class, but its not really hard as long as you understand the theory behind things...
Gibson486
18,378
it's very useful if you need to transpose thign in 3-d. Learn it, use, love it.
