Lindows 4.5 Developer's Edition Free, act quick!
aehlers
34
They should use Bittorrent. It'd decrease their server load and increase file transfer speeds.
dxpaap
572
I put the coupon code - but it still showed the $49 amount ? shouldn't it have shown a $0 total ?
and it still asked for credit card info ?
Is this what happened to others ? or did my coupon code not work ?
thanks
Entity
10,090
Originally posted by: Armoth
Thanks. I was #2 in line and then it errored out and I had to re-enter at #112. Must be the AT effect...
Just got the same thing. Wish they were using bittorrent for distribution. :p
Rob
cmccrkn
342
thanks
I think you picked the wrong product. Be sure to pick the Developers edition which is $59.
ttown
2,412
thanks
I bet you chose the regular edition and not the "developers" edition... the price on the dev edition is $59, not $49
Scroll down a little bit on the lindows page... I almost made the same mistake
jfunk
1,208
Sweet, thanks.
I'm sure the DL queue won't be that big for too long, it's just people jumping on this now. I'll download it sometime next week and try it.
BTW, to those that don't want to format a drive to try this, they give the ISO for running it off of a bootable CD if you just wanna check it out.
j
hevnsnt
10,868
Is there anyone who can upload it to my server, I am not at a place I can D/L it!!! ARRRGH.
jfunk
1,208
You don't have to DL it now, just create an account and "buy" it. It will put the various versions in your My Products folder to DL whenever you want.
j
TMPadmin
1,886
Okay everyone stop your downloads! I want to be first and I'm number 89 now. :)
Thanks Robisc, this will do just fine!
bryantson03
58
Can you d/l and install Lindows on a PC if you are already running Windows XP? Is there a way to switch between the two? Or do you need a seperate PC? Thanks.
hevnsnt
10,868
j
Just saw that, thanks
dxpaap
572
although, before I did the $0 cost (never populated the CC page), I was able to path to the FTP site that had 3.x-source and 4.x-source folders.
I was able to copy the folder to my hard drive (well I aborted after 20 min of downloading because it showed 4 hours remaining - @ T1 speeds). Not sure what was going on, since this was before I did the free procedure.
anyway down to 40 in the que
Entity
10,090
You can use a program like partition magic to create a separate partition for it.
I'm debating between using Lindows and Xandros on my laptop, just to have another choice for when I want to do development work. Not having much luck getting this to download, though. :|
Rob
Netopia
4
DARHLFJORUEOIPHF!~~
I've gotten to #1 three times now and then gotten an error message!
The one that I'm actaully the most interested in is the CD based version, so that I can check it out without having to install it, similar to Knoppix, Mandrake Move and SuSE live-eval.
Perhaps if several of us each d/l one version each we can then do a bittorrent deal?
Joe
chibchakan
2,349
We're sorry, but an error has occurred while processing your download. Please try your download again. If you continue to receive this message, please contact our support team.
I keep getting this message, anybody else? :confused:
Carnivore99
178
The first letter of the coupon code is a I, not a slash. And don't use the quotes.
