I recently installed Mandrake Linux 8.0 on my computer, and it's worked fine so far, except it just developed a little problem. For some reason when I now try and boot into Linux using LILO, it comes up with the message "Starting Linux" and then hangs. I'm using the Windows XP bootloader to load either LILO or WinXP. I can still boot with the boot disk, so I booted up that way and checked out the /boot directory. When I use a Terminal window to view the boot directory the file initrd.img is blinking red. I have no idea what this means, except that it probably signifies a problem. Any help would be appreciated! Thanks.
