lights on motherboard
crazychicken
I dont know what kind of board this is, but the onboard 4 LEDs light up RED, RED, GREEN, RED
is there a standard meaning for this? is it board specific?
i switched the vid card... no luck
system seems to turn on but no display
next step is to switch ram...
any other ideas?
thanks
david
Some msi boards have those. They're used to trouble shoot problems. You might want to check the cpu. A bad one can do what yours is, so can a cpu not seated correctly, or a cpu that the board doesn't support.
Good luck
