OK, without going crazy deep..
- Had a big thunderstorm early AM today
- Power burped
- Lightning spike (or something) got through my UPS and burned out the power adapter on my ATI 9800 AIW.
- Nothing else is failing (atm), system works with another vid card
So how the hell does that work? The Y adapter that feeds power to the video card, on the white plug that's connected to the card, the 4th pin (cable color feeding that is red, other 3 are black black and yellow) has brown burn marks on the plastic. Upon boot, it was beeping twice every second with a message on the screen that stated to the effect of "make sure the power is fed to the video card."
So assuming I might get lucky and the card might still work with another adapter, how the freak can you better guard against lightning? Is unplugging the cable from the wall the only answer? Is there a device that will 100% blow itself out first and NOT allow electricity to pass past that point regardless of how big the spike is? I'm not an electrician by any means, I just spend a lot of money on hardware and if a spike can get through any one of my 5 UPSs I have in my house, well - that ain't gonna work.
Any tricks / tips from someone who's gone through this too? Or found a better way? Any help is appreciated, thanks
