lighted switch for fan control wiring question
sohcrates
7,949
What's up?
i'm building a "baybus" type fan control device for my buddy. basically, it's just two lighted 12 volt single pole single throw switches from radio shack.
i had a question on wiring them up though. the switch has three connectors on it. they are labeled
1) ground
2) positive
3) ACC
I figured i would just cut the positive fan wire and put the switch in series with it. but my question is:
how do i hook up the "acc" connector? i thought i might just series it with the "positive" connector, and assume they use a shared ground.
anyone ever hooked up one of these lighted switches before? (i assume they light up when the switch is on, and not when the switch is off)
thanks!
