light storage
Brado78
293
4
I was wondering can light bulbs be stored on there sides? A lot of small package of light bubls in one big box ,will gravity bend or wreck the filament inside the bulb, for long time storage? like in the picture?, but the bulbs are in there own packages.
Thanks A lot :D
BoomerD
66,718
15,117
Not only should light bulbs NEVER be stored or used in a horizontal position like that, they SHOULD ALWAYS be stored and used in their natural position...with the base up.
(fixed typo)
ElFenix
102,408
8,596
what is this, 1920? who uses bulbs with filaments anymore?
35,609
Filament bulbs are pretty tough, there's a good chance you haven't ruined them yet. You should remember to rotate your fluorescent tubes a quarter turn every three months.
highland145
43,973
6,340
Clockwise or just opposite the earth's rotation.
14,087
I find that the new LEDs don't stimulate the prostate like the classic filament bulbs do.
YMMV.
You need to get the ones with the big heat sink. Just make sure you sand them down a little as sometimes the edges are sharp.
As a side note I really like the light the old style Christmas bulbs produce, but they burn out so much. Every year I end up changing like half the bulbs. I finally switched to LED but I find because they put in low end LEDs they're just not as bright. Would be nice if they put like 5x modules per bulb instead of just one or just use some higher quality COBs. Open source RGB addressable ones would be nice too. Open source being the key word. They do make some addressable ones but they rely on some app. Will that app still get updated in 10 years from now? Probably not.
lxskllr
60,936
11,267
I like the *really old* painted c7 lamps. They looked great but you had a real risk of burning your house down with them due to heat, not to mention energy use. I don't know what the wattage was, but I'd bet it was at least 15w/lamp.
shortylickens
80,287
17,082
Are you bitches still using light bulbs?
ROFLCOPTERS MOTHER FUCKERS I USE NUCLEAR FISSION AND PROTON ACCELERATORS TO LIGHT MY FUCKIN HOUSE!
