light blub problem
Omegachi
so if there is a 60W lightbulb and its running at 110V AC... the resistance should be 201ohms right? because P=V^2/R
but when i measure the bulb's resistence, it shows about 16.5 ohms... why is that?
Resistance increases as temperature goes up. Tungsten filaments get VERY hot.
Edit: BTW, the increase is linear: R=R0+aT, where a is the thermal resistence coefficient. Typical incandescent bulbs heat the tungsten in the 5800+ degree farenheit range.
