Don't known about Win2K, but in XP you just set it up like any other screen saver and tick the password protect
box.
Found this site offering a free utility to allow a single program to run as a service:
Firedaemon
Just gave it a go and it started Lifemapper o.k. (process listed and CPU jumps up).
(Selected Window Type=Normal, priority=Low, no login info)
The catch is you don't get the tray icon, or any
other means of interacting with the program.
George
Originally posted by: CyberDuck
Btw: Does anyone know how to put the lifemapper screensaver as the login prompt screensaver in windows 2000, and does the screensaver continue to run if the monitor is sent into sleep mode?
A better solution is of course to run it as a service, is this possible?
